Recently I decided to refurb my spare standard front brake calipers, just to have them ready in case I ever needed them. I've refurbed quite a few sets of brakes before, so wasn't concerned. I also got OEM Honda refurb kits as I don't like the quality of aftermarket ones.
All was fine until I tried to secure the rubber boot in place at the mouth of the bore. Most boots use either a lip, or a clip to secure the boot to the bore, but the Honda solution seems to be to have it 'pressed' into place around the lip of the bore and then retained by friction! However the bottom ring of the boot just won't pop into place. It will engage on one side, but then no matter what you do will not pop down around the whole circumference (IYSWIM!). After 90 minutes of trying, with both calipers, and both boots, I gave up before I lost the plot and grabbed a lump hammer!
Has anyone done this before and got any ideas on what I might be doing wrong? The mating surface at the lip of the bore has been thoroughly cleaned and prepped, the boots are brand new OEM Honda, so I can't see what else I can do! I've checked on Lings and there definitely isn't a clip - it should just pop into place, but doesn't!!
Anyone got any ideas?
