I have tein superstreet,i just replaced them with koni adjustable yellows with eibach springs with reinforced top mounts,the koni setup is better in my opinion,as tein shocks had short shafts and linier spring rates,and very short springs
I got 4 koni yellows from larkspeed for £425 delivered,the reinforced top bushes are these below,i have the honda part number,but not sure if uk and usa numbers are the same,might be worth buying 1 just to see.honda uk are £18 each.you need 8,worth every penny.the stock bushes are very soft rubber you can bend in your hand
