-Rich-
The first issue is with the rear wiper, it's been working slowly the last couple of weeks but stopped completely this morning! Are the tourer and saloon motors the same? I am ***uming it's that or could it be something else?
The second issue is the front drivers washer jet is just dribbling out. The passenger side is fine. I've removed the jet from the tubing and tried running hot water through it. I've also put a pin in the slot in case it was blocked there. Is it possible for the jet to block up to the point it needs replacing or could it be another issue? I ***ume the tubing is ok as the passenger side works.
I did try squirting the screen wash without the jet fitted and it didn't shoot out, just dribbled, but so did the passenger side. After doing that I also noticed a puddle next to the passenger wheel, I'm guessing it ran down behind the scuttle panel and that was the quickest point for it to come out.
