SayamaAccord
And still...
45 for the petrol. That 80 looks a beast mind.
when you say "behind the glovebox" do you mean from the engine compartment or from inside the car ?geoffdragon said:In my search for answers, I have come across a bank of relays behind the glovebox.
Anyone have any info on these please ?
probably unique to the diesel as there is far less room in the diesel engine compartment. I'll take a look on the DVDgeoffdragon said:Inside the car. Unclip the glovebox stay on the side nearest the door. Squeeze the top sides of the glovebox together and it will swing down. Cabin filter and bank of relays in front of you.
I intend to leave mine for weeks, and check the A-h each day.geoffdragon said:Hope that meter arrives soon
I intend to connect it up for 24 hours, see the total draw and average it out. Hopefully come back to around 24maH.
I know there will be a spike when locking the car, but that will be so short it shouldnt matter.
Nope ....hope they arrive by Friday at the latestgeoffdragon said:Oh well, the meter hasn't arrived.
I'm sure Royal mail are delaying 2nd class Post.
Wonder if yours has come Freddo.
Yuasa Silver arrived and fitted today. Always been a bit of a slow & lazy starter...until now. Nice quick lively turnover. Would recommend.geoffdragon said:I wouldn't be able to order a battery till Tuesday anyway.
Yeah I know, but that means getting out my 1/4 inch set which I don't keep with my car tools as I don't expect to use 1/4 inch set very often on a car .....especially a battery terminal. I think the Civic models of the same year are the same, not seen any other make of car where you needed a 1/4 inch set to undo a battery terminal especially when the other terminal is easy to accessCliffordski said:A 10mm socket on 1/4 inch ratchet slides straight under the positive terminal overhang onto the nut.
That's the standard battery in the 2.4 (it's the same Panasonic as was fitted at the factory)geoffdragon said:That's a completely different clamp from mine. That looks like a "space saver" battery too. Also used 10amp cable to connect up.
3.5 Ah over 24 hours is definitely not rightgeoffdragon said:Hi. Looks like I have a hidden problem.
Ah draw for 24 hours 3.574amps
Wh draw 42.8watts.
That's an average of 149 mah. Even taking into account locking and unlocking car it's way to high. No wonder the battery is going flat.
Question now is how to find this sneaky drain when locked and standing the dmm only shows 24ma for at least an hour after closing car up ?
