geoffdragon
Freddofrog. How is your meter working out ? Just read mine after an hour and it's showing 0.133ah. Can't understand it because dmm is only showing 24ma.
I'm ***uming that you haven't before, if not ......geoffdragon said:Sorry can't post photos ?
Maybe it took a few minutes for everything to shut down and it was using 0.2A+ in that time.geoffdragon said:Freddofrog. How is your meter working out ? Just read mine after an hour and it's showing 0.133ah. Can't understand it because dmm is only showing 24ma.
Well let's say it used 60A for 1 minute (!!!) .............. that is only 1 Ah to add on (because 1 minute is a sixtieth of an hour)Cliffordski said:Maybe it took a few minutes for everything to shut down and it was using 0.2A+ in that time.
1 Amp for 1 hour = 1 Amp-hourCliffordski said:I thought 1 Ah will only use 1A in an hour not 60A ? :wacko:
Cliffordski said:So are you guys measuring A or Ah over 24 hours?
To be more exact, it's sampling Volts and Amps very quickly and then calculating Wh and Ah at each sample, but we have to know the amount of time it's been connected to calculate average amps.geoffdragon said:The meter indicates the number of cumulative amps used over any period of time you like. Then you can work it out from there
Do you mean 0.133A?geoffdragon said:Freddofrog. How is your meter working out ? Just read mine after an hour and it's showing 0.133ah. Can't understand it because dmm is only showing 24ma.
No he means 0.133 Ah (I know, sometimes he drops the "h" and writes "A" where he clearly means "Ah", but he doesn't write "Ah" where he should have written "A")Cliffordski said:Do you mean 0.133A?
Note also that 1 hour is not a good sample, because any additional currents used for a few minutes will cause a bigger Ah reading, whereas over 24 hours that additional current for a few minutes will not show up as muchfreddofrog said:No he means 0.133 Ah (I know, sometimes he drops the "h" and writes "A" where he clearly means "Ah", but he doesn't write "Ah" where he should have written "A")
He is puzzled because he got 0.133 Ah with the meter connected for 1 hour, but at 24 mA on a DMM it should have thus given 24 mAh over 1 hour
Still confused sorry - please bear with the slow learners such as me - do amps measure amount/volume in the same way as gallons do with water?freddofrog said:Let's ***ume a device is using a constant 1 Amp for 2 days
That will give 48 Ah
But if the device used an additional 10 Amps for 1 hour during that time period, then a meter will show 58 Ah
The problem is then to find out when and why the 10 Amps was used (or maybe it was an additional 5 Amps for 2 hours)
edit: a couple of edits LOL
As long as you are getting 20-30 mA after full shutdown and it starts okay when you want it to then that might be the best deal you're going to get!geoffdragon said:Well, I've tried a few more things.
Boot light disconnected for 15 hours - no difference. ( 133mah average)
Alternator disconnected for a hour - no difference. (166mah )
Fuse 20 out for an hour - no difference ( thought it may have been something to do with headlight adjusters ) (169mah )
I know these are short trial times thats why the readings are higher, but I would have thought if I had found the draw it would have shown a recognisable drop in consumption in an hour.
I wonder if a sticky relay could cause this drain.
If you remember, in an earlier post where the current dropped 124ma when I closed the boot. I think now that could have been the boot light going out, noot the micu.
Fast running out of ideas now. :wub:
Cliffordski said:Still confused sorry - please bear with the slow learners such as me - do amps measure amount/volume in the same way as gallons do with water?
If so then isn't an Ah the rate of flow not the volume that has flowed?
But over 24 hours he got 3.574 AhCliffordski said:As long as you are getting 20-30 mA after full shutdown and it starts okay when you want it to then that might be the best deal you're going to get!
Best thing to do is to extend the wires on the meter so that you can see it without opening the bonnet (such as dangling down under the car, maybe behind the nearside front wheel).geoffdragon said:Well, I've tried a few more things.
but that's the point .....something else is coming on intermittentlyCliffordski said:He couldn't have if only 25mA per hour was flowing....one of those figures must be incorrect.
btw .....no he isn't seeing 25mA per hour , he is seeing 25 mA, and then (after 24 hours) he sees 3.574 AhCliffordski said:He couldn't have if only 25mA per hour was flowing....one of those figures must be incorrect.
edited your sentence ....geoffdragon said:That's right. If the draw on the dmm is truly 24ma. That should be in the region of 0.576 amps in 24 hrs. But it is 3.574 amps in 24 hrs so that 24 ma is a false reading for some reason.
:lol: :lol: :lol:Cliffordski said:LOL I can almost hear you and Jon chortling away
