CarlStewart
HI mate - done as above and when rev'd you see the movement - seems fine.
The reason I disconnected the FSV was because for some people it run better once disconnected (suppose I was clutching at straws)!
Would you say FSV solenoid is my next port of call ?? OR as it moves does that mean solenoid is ok? (sorry to sound thick!)
I've got a turbo boost solenoid from a breakers on its way - £20 - thought as it was cheap enough may try that also!
