Hi guys,
Thought I'd share my latest efforts to improve the running of my trusty Tourer....
Having dealt with the EGR issue I decided to give the butterfly valve a good clean up, and go one step further and de-coke the inlet manifold, have noticed some pretty heavy carbon deposits in the pipe from the EGR.
Started by removing the engine cover:
Next up disconnected the feeds to the swirl valve solenoid....and removed the swirl valve....as previously seen this was very glooped up with sticky carbon deposit and I doubt it was operating well or allowing a smooth passage of air:
Dirty parts....
This shows the inlet manifold after removing swirl valve:
Inlet portion:
Swirl valve:
Sensor:
Next the fuel rail was removed to allow access to remove the inlet manifold:
Then off with the inlet manifold to reveal heavy carbonisation:
We scrapped out what we could manually...which was a lot!
Next up the manifold was placed in a bucket of coke to soak overnight....I am reliably informed this is a great cleaner!
Finally I cleaned up the swirl valve etc using brake cleaner, a tooth brush and an old rag....
Part two tomorrow when we will finish cleaning the inlet manifold and put the lot back together
Dirty parts....
Inlet portion:
Swirl valve:
Sensor:
