2.2 Diesel Fan Belt without Air Con
Grayedout
South Ayrshire
Just for reference if anybody needs to run their car without the air con compressor then you will need a PK1425 belt.
This is also ***uming you have made the mod to remove the extra idler pulley.
Hope this helps.
Hope this helps.
useful info, problem is remembering where all these useful bits n bobs are, I just did a search using "PK1" and found quite a lot of different belts in different threads, including this thread which was starting by you too !! ;)
http://typeaccord.co.uk/forum/topic/22149-air-con/page-3?hl=pk1
