Hi all
Im a new Accord owner and already got some great tips from the site.
Just bought a 2004 CTDI and have a prob with the climate/air-con system.
1. Pressing A/C, shows as "on" ,i hear the revs change briefly, cooling fans come on
2. Doesnt go cold and cant hear the drier working
3. Checked the low-side pressure with a guage and the pressure is a bit on the high side.
4. Checked the fuses and no fuses blown
4. Basically, the car only blows ambient air - i also turned the heater on and it on pumps out heat on Hi setting - nothing in between apart from 1 degree under Hi.
Any suggestions? Ive been told that Hondas have a safety cut-out switch which stops the a/c from working if the pressure is too high or too low? Id guess the last owner has had the system charged too high.
My local Honda dealer is a well known brand owned by a gentleman whos initials are also A-C! not sure if im allowed to say the name on here however past experiences with these dealerships is less than happy so wanted to see if any owners have had the same issue!
On a separate note- cany anyone recommend good dealers either Main or independent for future servicing on East Coast of Scotland??
thanks guys - im not the most technical on the planet!!
