Good evening.
Please forgive me if I have started this new topic incorrectly or without the correct permissions.
I have recently purchased a 2004 i Ctdi with low mileage and full service history, and I have to say it has been a fantastic car.
Recently, however, the car has shown its gremlins, and I'm terrified its going to cost me a pretty penny to get it working again.
Let me describe in detail what I experienced.
Driving home I noticed that the turbo whine (or what sounded like turbo whine) increased in volume to the point where it became a howl followed by a loud whistling noise. This only occurred when accelerating. No gas + cruising made no sound.
After nursing the car home, I jump online to research potential problems. I thought I found the answer when I came across a post that described my noise quite perfectly. The post concluded that it was a missing jubilee clip on the air intake hose. So I run outside and check mine, only to discover that I too am missing a jubilee clip.
So off I rush to the shops to find a jubilee clip only to find out that the loud howling and whistling has evolved into a very loud rattling (which progressively gets worse).
I get the jubilee clip, and secure the air intake hose (wishing that that would sort the problem) - it doesn't.
The loud rattling has become so loud an obnoxious that it is impossible to drive the car.
I don't seem to have lost much power, however I do think some boost has been lost.
After further research I believe it to be one of three things:
I appreciate the help in this regard, as I need to begin a plan to fix the car.
- Failing water pump
- Failing alternator
- Failing timing belt / drive chain.
