montempeaux
Hi All,
My car has developed a really annoying rattle from under the roof lining in the location circled in the picture.
http://i1094.photobucket.com/albums/i450/montempeaux/AnnoyingRattle.jpg?t=1300022066
If I apply light pressure to the lining the rattle stops. I suspect the most likely culprit is the cable that (I imagine) runs from the roof lights at the front console to the roof light in the centre. I want to try and get under the lining to sort the problem - due to the location the most sensible option would be to remove the from console that houses the specs holder, two reading lights and HFT mic. I have removed the two bolts in the specs holder, but I cannot work out how to remove the unit. I suspect there may be more bolts (perhaps under the lights?) or clips . I have removed the Mic and there are no bolts there. I was reluctant to try brute force in case I broke something.
If anyone has any experience of removing this, or a pic from a manual etc I'd appreciate your guidance
A search located this: http://typeaccord.co.uk/forum/topic/837-diy-overhead-ambient-lighting/page__p__8643__hl__roof+lining__fromsearch__1#entry8643
But I'm not too sure exactly how to remove the console
M
M
