Hello, I think that I have an issue with the brakes of my car. It is an Accord 1.8 16v 98, CE8 - left direction (don't know if you tell it like that). When I bought it there was a problem with the rear brakes. It was fixed by the local services but I don’t think it was made correctly. That's why one day I lifted the back and blocked the brake pedal. Supprise- the wheels were moving without any problem. So I removed the piston from the caliper body because It was blocked. I changed the brake fluid and the brake pads. When I tried to push the air out of the system there was a problem with the rear right wheel. The air could not pass by the bleed screw- it was corked. I succeed to unblock it and the fluid started to go out. First I did the rear right wheel, than rear left, front left, front right. It was strange beacause sometimes the pressure was strong nex time slight. The engine was started. I ***embled every thing but still don't have the wanted result. I feel that there is no pressure on the rear wheels when I push the brake pedal. Very often the ABS turns on without reason for me because of this. The hand brake is working and when I pull it I feel the braking force. So I don't think that a blocked piston is the reason. On the 4-5/12 it was raining, and all the disks become rusty. When I take a tour the front disks were cleaned but the rear were the same. So I don't know what to do... I know that the pressure is almost on the front wheels but it should be some on the rear also.
