cluster failure 1.8 Accord
jerryrabbit
swindon
Accord 1.8S 2001
Today i started the car and all the gauges in the instrument cluster stopped working. They all went to zero, save for the temperature gauge which went to the max mark. The fuel light also came on, when I still had fuel..And there was no digital display on the trip meter...The engine run ok, Is this the circuit board behind the dash clocks a loose wire or something..
Did the EML light come on?
Also, as the temperature gague went all the way to hot, did the fan come on? Have you checked all the fuses? There is a box on the drivers side of the car, as well as one in the engine bay.
Also, I know it's a long shot, but have you tried an ECU reset? If not, disconnect the battery for about 10 mins, then reconnect, and see if there is any change.
