Kuang
I was wondering if these might ring bells with anyone:
I bled my clutch after the firm pedal/low bite issues I mentioned earlier and it's better but still not right - the bite is a higher now and there's tons of grip, but you still seem to have to bury the pedal sometimes to notch it into first and second. That's a big range, and it makes no sense; it's almost as if the spring plate has play on it as well as feeling too stiff. I still have the occasional buzz on taking off that sounds like the release bearing, but I also noticed that there's a strong 'rustling' sound under drive that vanishes the moment you dip the clutch. It disappears even if you hold the throttle steady whilst doing so, so it's not the engine. I'm wondering if it's also likely to be that bearing or something else in the transmission? I wouldn't think it's in the gearbox as there'd be enough momentum for the noise to fade quickly instead of stopping immediately.
Secondly, when I start in the mornings I get a slight whine from around the serpentine belt which sounds a bit like it might be the alternator. This stops after about half a mile. My friend's Civic Type-r has similar but not as loud, so I wondered if it was just how these were when under a strong load? There's plenty of charge and I'm not getting dimming lights, etc so I presume it's doing the job. This also coincides with a slight whirr from the belt itself that lasts for about the first ten minutes of a drive but then vanishes completely. I've checked and the belt is visually fine with the indicator sittingly comfortably within the wear marker.
