I have the same kit, mine came a kind of gunmetal colour finish.
I'm more than happy with the scope of adjustability with these compared to the balljointed type adjustable rear upper camber arms. Mainly because you have a greater range of scope to re-adjust your toe setting once you've set your camber where you want it. I know this as my friend couldnt get enough camber to clear his 8.5" wide buddyclub wheels as any more negative camber would throw his toe well out. In the end he rolled his arches on his CL7 to stop the rubbing as the camber kit couldnt tuck his wheels enough.
