Drivers side mirror indicator light | How to fit
vn125250
London
Accord 2.2
Hello to you all,
The lens for my drivers side mirror indicator light has cracked. I have ordered a new one which should arrive tomorrow. Any idea from anyone on how I can fit it? As I understand I need to remove the mirror but not sure where to start.
Any help appreciated.
From memory you gently prize out the mirror from the bottom.
This releases the clips and also I'm sure there fixed with M3 tape or a gel.
Once off there is a plug into the heated mirror that just unplugs
I'm sure then you get to the screws to take the mirror apart.
Thanks Brett, All that was needed in the end was a flat screwdriver (helped release the clips behind the mirror) and a philips screwdriver (to take the screws off) once the mirror was off. Took me an hour but I should have done it in 30mins, messed up a little putting everything back together.
Good man glad your sorted bud
