AcesHigh
Hi,
I'm after a bit of advice on how to get at the EGR plate on my Type V to give it a once over.
The reason for doing this is because the car occasionally stalls when turning at junctions when running on lpg - it has just had a gas service and I was told that the ECU's had a discrepancy and that I had a vacuum leak and/or the EGR valve needed replacing. This is a £375 part from Honda and as I have been reading about cleaning the EGR system on this site I thought I would have a go at cleaning it before replacing parts. I'm not an expert at mechanics but I don't mind taking my time and double checking everything.
I have read through the existing EGR related posts and looked at the You Tube videos but the Type-V engine bay seems different; on Eric The Car Guy's video it shows the wiring harness and fuel rail being pulled to the near side and 3 nuts to remove the fuel rail. On my Accord, the wiring harness goes right across above the fuel rail and I only have two nuts to remove the fuel rail. The wiring harness looks like it is connected to different parts at both ends so can't just be pulled out of the way as in the video.
The 2 nuts holding the fuel rail are in the most awkward of places and I cant get a ring spanner of socket over them - one (near side) has the fuel inlet into the rail directly in front and the other (off side) has some other metal pipe that seems to be welded to the fuel rail. I have tried an open ended spanner on one and the nut is so tight that it started to slip so I gave up - I don't want to damage the nut.
Does anyone have any suggestions on other ways to get at the EGR plate? I only want to clean it out, is it possible to put carb cleaner (or something) down the hole with the EGR valve removed?
Many thanks in advance!
