egr valve
04tony
Dublin Ireland
07 accord ictdi
H'i guy@s
04tony here in dublin
I have an 07 2.2 ictdi 168.000 miles i am currently suffering the dreaded stalling /hesitation.
my egr valve is showing 40 % open at idle i have cleaned valve/inlet manifold and so on.
no dtc's car is very hesitant.
any suggestions would be very helpfull
thanks in advance
Hello
If you have access to the HDS diagnostics equipment then you can run a egr test and determine the health of it.
If you've cleaned it, and it seems free to move, then I'd look at the actuator.
H'i guy's
sorry i took so long to reply,but i have solved the problem.
took inlet manifold off in desparation only to discover in was completely stuffed.
took about 2 hours of stabbing with screwdriver to loosen as much as possible.
then soaked for 1 hour with foaming ovencleaner.
results spotless manifold &guess what, no hesitation or stalling what so ever.
egr sitll shows 38% on torque but honestly guy's car is brilliant.
H'i guy's
