Greetings to all.car(2000 1.8 engine) failed the emission test this week but prior to it I changed the whole exhaust system including cat converter and also a service on the engine(oil/filter/air filter/clean plugs).took it back home and replaced lambda sensor and spark plugs (recommended ngk/ntk brand) and drove it for around 40 miles mostly red lining before the 're test but still failed. No engine light on the dash but I checked it anyway using the paper clip test. Result is that the engine light just stayed on and srs went away then came back, done it again with the same outcome so not sure if I done it right. Not sure if relevant but the cat I installed has got a hole for something but I just left it plugged with a bolt that came with it. It failed on excessive CO content after 2nd fast idle by the way. Any advice would be much appreciated please on what to do next apart from sending it to scrap heaven. Thanks.
