Jon_G
No Longer Active
Today will be known as "Black Wednesday"... my car has just suffered it's first MoT failure
Failure was due to a worn ball joint on the front suspension upper arm (drivers side), so part 5 on this Ling's diagram... HERE and the top (horizontal) yellow component on Freddofrog's thread... HERE
Has anyone replaced this part themselves recently? If so, can you recommend a supplier (Honda are a little pricy so I'm looking for aftermarket, but I will check with HH). A quick look on eBay found this cheap part... LINK and also this slightly more expensive (but Delphi) one... LINK
I believe that you can just buy the balljoint and press into the old upper arm, but I don't have access to garage facilities, so I will need to buy the complete arm... it looks like a fairly easy DIY, but any feedback/thoughts would be appreciated! Do the two mounting bolts and ball joint shaft usually come out reasonably easily?
