Gaskets Required
Grayedout
South Ayrshire
My 2004 2.2 iCdti is about to go in for a new set of chains but I have agreed to source all the parts as I know it works out cheaper.
Currently got:
- Chains kit
- Rocker cover gasket set
- Injector washers
Anything else that I need? Are the end plate and the sump actual gaskets or are they just liquid gasket?
You will also need loctite 5920 copper liquid gasket for the chain cover and the sump. The o-ring on the oil filler tube, but you can probably get away using the old one.
