gear oil
djcoops
dublin
accord
Hi all
iv drained my manual trans fluid only aprox one litre inside? no leaks. im sure there should be a lot more. honda dealer said 2,5litres facelift model deisel.
kind regards
There is actually a checking point, a bolt can be removed to check if the right amount of oil is in, anything over will drain out. Check your hand book, it says it in there how to test?
