Gen 7 reversing sensor fault
redsectora
Nottingham
Accord 2.2 cdti ex
Hi
Anyone got Factory Fitted reversing sensors on their car? I know mines dealer supplied & fitted because i have the original purchase receipt for the car.The fault I have is when I put it in reverse it beeps twice then that's it.Nothing at all when revering up to an object.
I don't think it's a after market unit as it was fitted at the main dealers.
Can anyone tell me the location of the sensor module and if any of you have had a similar problem
I think that most (if not all) of the 7th gens with reversing sensors were fitted by the dealer (mine included). It won't make any difference whether it was factory fitted or not.
I think the problem you describe is that one of the sensors has stopped working, it could be anything. Easiest thing to do for a start, is to make sure all the sensors are clean. If that doesn't help, then you might have to check the wiring (probably have to remove rear bumper for that).
