Hi.
Im in search for new winter tyre set and i was wondering can i fit 205/60R16 on 7th gen facelift(2007) accord wagon. How much will there be speedo error?
Currently im running 205/55R16 winter and 225/45R17 summer set both on original honda alloys and on speedo i have +5km/h error and with both sizes accord is like glued to the road... It is hard to get a tyre squeel in tight corners in dry conditions.
But i was wondering about /60 set, as with them car would sit ~1cm higher which would be better in snow/winter conditions because accords dosent have world class clearence and there would be more sidewall rubber to dampen potholes. But will it change handling? If yea, then is it worth the sacrifice? and does it give more speedo error? If yes by how much?
On my side door tyre pressure sticker only 205/55R16 is written.
Thank you for your replies.
