brodziu
Hi.Does anyone know how to dismount wing on tail gate in tourer? Are there any screws behind upholstery? Thanks for any help.
I tried but it brokeCrowbar?![]()
Ok,
You need to remove the side and upper trim.
There are then 6 bolts visible to remove.
Disconnect the brake light.
Close the tailgate and remove the 5 clips (good idea to buy some spares first though).
As you lift, remove the washer tube & grommet.
Refit in reverse order. Use 9.8Nm on the bolts to tighten.
Now, unless you are about 5ft, Japanese and incredibly cute (and of course a girly), then I can manage my own back.
