Ignition switch Fault
robb1330
wigan
2000 1.8 sport
Afternoon Gents,
Has anyone had any experience in replacing the infamous faulty ignition switch. Mines started to play up again, after being replaced by an auto-electrician about 4-5 yrs ago! Ive noticed with the engine running, the key being in position II, a very slight nudge can cut the engine without actually engaging position I. I've seen a couple of videos on youtube (american), and if the same setup -it seems a straightforward job.
Is anyone familiar with the replacement part number from our friendly neighborhood Honda dealer?
Cheers guys
Accord 1.8 Sport, Yr 2000, 79,000 miles..........................
I have changed mine some time ago(only what is inside electric/rear side of ignition switch). Used one from Rover600. so far so good.
Maybe you have big weight on your ignition key keyring? weight on that keyring damages ignition switch over time
