Hi guys, I've got an occasional knock from front left corner .After taking the wheel off there is play in the bush on the lower control arm nearest the front bumper. I've added a picture. There is no play in the lower or upper ball joint but I think the control arm will have to come off to press out the knackered bush, will it not? Is it worth getting the lower ball joint changed at the same time?
Does anyone have a part number or proper name for the knackered bush in the picture
Cheers, Alastair
Cheers, Alastair
