I have 2008 accord. After being on holiday for 2 weeks it wont start- the brakes seems to be jammed and the ABS signal flickers when try starting and makes funny noise .The brakes doesnt seem to work. My friend use to start once in few days while I was away and the battery is live as the lights works ok. Any reason why it does so.
Siva
Repeatedly starting a car without letting it run and top the battery up will eventually cause the battery to go flat. What noises is it making? Clicking noise?
As Dan says you need to measure the battery output to see for definate if the battery is to blame.
Also what do you mean about the brakes not working? If you release the handbrake will the car move at all. If not your brakes are seized and may need stripping to free them. Sometimes if you can get the car started they will release.
I think from what you've put there's two faults here both caused by standing unused.
