Newbie with many questions, 2007 Accord EX
cpikey316_
Leighton Buzzard
Honda Accord 2007 EX
Sorry about the mass of questions here, just bought this today and there are some issues I need some advice on!
1. Sat nav is missing a disc, where is the best place to get one and what do I need to look out for.
2. Dual zone climate control isn't working, Passenger side vents showing 7C on my temperature probe (a cooking one!) and drivers side showing 21.3. What could this be?
3. Upper display doesn't light up. It will, if you press the plastic above it!
4.This little cup holder cubby doesnt close. Is there a fix or is it a new one.
5.Door seal, need a new one, how much am I looking at?
6. Driver side headlight has some condensation inside. Can I dry this out, or do I need a new unit?
Phew, quite a long list, I hope I dont find anything else! Any help is appreciated!
re the upper display I have the same problem, give the dash a bash and it works, (for a while) but comes and goes of it's own accord. If you find an answer let me know. There was a recall on the headlamps not sure if you would qualify now, but all that was done done was the fitting of clips, to be fair though it appears to have worked for me. I have 2 disc copies neither of them work for me but may help you if you want them give me a buzz.
The upper display not working is probably just a loose connection. It is actually quite easy to get it off (I had to take mine off to paint it). There are 6 clips, probably a guide here somewhere.
Thanks for that but had it off and pulled the plugs, cleaned them but no good result.
