Nissin 17cl15vn caliper
viggen333
Tallinn Estland
ACCORD Tourer CN2
Hi
I found the nissin 17CL15VN two piston brake caliper from Honda Legend KA9, but they are designed for 280mm brake rotors. Сaliper body is compatible with caliper brackets from ACCORD TYPE-R which are designed for 300mm rotors? If the they fit, where I can buy only brackets?
I would suggest breaker yards and Ebay mate. Not sure how much they are brand new?
check this
http://typeaccord.co.uk/forum/topic/8820-type-r-twin-pots/page__p__98489__hl__legend+calipers__fromsearch__1#entry98489
also it's been said few times on forum that legend calipers will fit but the problem is that these are mounted at the back of the wheel in legend not at the front like in accords, so it's problem with bleeding screws, I'll suggest you to get proper ATR calipers which are P&P with no problems at all ;) and you can get them from breakers
