Noise when its cold - the movie
dexter7d
Peterborough
Honda Accord VII 2.0
Hi.
Im new here but im hoping you would be able to help.
My Honda - Accord VII . 2.0 Vtec, 2004, 63000 miles
Wheel is that noise coming from ?
Its only if the dngine is cold. 10-15 minutes later is ok
Can I simply use the lubricant and spray one of it ? Am I gonna damage anything ??
The lubricant I would use is http://imgup.pl/di/U75P/IMAG0367.jpg
and the movie with the noises is herehttp://www.youtube.com/watch?v=B7BMQ46nRIA&feature=youtu.be
Welcome to TA dexter at a guess mate that sounds like its coming from the Alternator.Have a search this is quite a common thing with older Accords.
This is from a diesel but still probably the same cause.
http://typeaccord.co.uk/forum/topic/11712-7th-gen-new-aux-belt-alternator-diy/
are you sugggesting that the belt is wrong ? to short ? nothing its damaged ???
can I use that lubricant I mentioned to check whether its one of the wheels ??
I personally would not use any Lub on this tbh.
It's hard to tell what the problem is but I will take a guess its one of your bearings gone.
Maybe the Alternator or one of your pully wheels.
I'm not 100 % but if you take of your alternator belt this will diagnose what pully is at fault.
Wait to see what other members say before you do this.
Have a look hear iv done some digging and it might be a case of just a new belt.
http://typeaccord.co.uk/forum/topic/1511-cold-morning-squeal-help/
This may help........
http://accordownersclub.co.uk/7th-generation-accord/116-i-ctdi-noise-alternator.html
http://accordownersclub.co.uk/content/honda-diesel-accord-drive-belt-alternator-belt-poly-belt-change-71/
hi
thanks for help
it might be the case of changing the belt only.
I am gonna check that tomorrow
look for a thread I made a whilst back about an alternator belt /alternator change. I made a video of the noise coming from the alternator before I fixed it :)
