Hi guys, I have a 2003 2.4 Type-S, done around 90000 miles. Am getting this fault code and have cleared it and it re-appears after a few seconds of driving Car drives fine although idles low and when accelerating, have noticed the odd miss. After searching the forums, it appears that it's likely that the timing change has jumped (presumably not by much due to the smoothish running?). However before I go further would like to check the sensor/wiring etc myself, my question that I can't seem to find the answer for is where abouts is the camshaft sensor?! Presumably on the top somewhere under the cover? Also, is there anything else I can check that could be causing this as am burying my head in the sand about the timing chain?!!!!
One final thing, is it an easy job to see if the chain has jumped? Presumably need to line up the crankshaft to TDC and see if the cams are in the right place, are there markings for all of this?
Cheers,
Jon
Cheers,
Jon
