Mr CL7
Chaps,
I have noticed recently that my passenger side headlight has alot of condensation building up and is getting worse. I installed my HID's in 2008 and have not had a problem since. I am a little concerned as to why this is happening now?
A recall was done in 08 to attach metal clips to the headlights as the glue used to seal surround was cracking and was a common problem, and as i am aware, some members on this forum have had a similar issue. If you haven't checked this it may be worth your while to ring the honda head office and provide them your car reg and they can tell you there and then if anything requires replacing for 'free' if it is a recall issue.
I spoke to CJ a few days ago and he suggested i remove the headlight(s) and dry them inside out with a hair dryer on low level heat. The silica gel bags may have also become perished i.e wet and may also require replacing. Lastly he said to seal up all the holes to prevent any moisture getting in.
Now this might seem a dumb question CJ BUT after talking with CJ i had a looksy on various US forums that have had the same problems, and they have placed the headlight in the oven and baked it then resealead it again. CJ, is this what you were trying to explain to me? Sorry buddy :unsure: It doesn't seem very safe, or is it? Last thing i want is a jelly structure headlight.
Thanks,
Faz
Thanks,
Faz
