My 2007 Accord Tourer has got some sort of gremlin that is causing the brake lights to be a bit random. They only come on when the brake pedal is pressed (so far, so good) but which ones illuminute changes all the time.
The two left ones are consistent and operate as expected
the spoiler-mounted central light works about 50% of the time, seemingly without rhyme or reason.
The right one mounted on the bootlid only works if the right hand indicator is also switched on. It doesn't flash, it just comes on when you click the indicator stalk
The right one mounted on the corner of the body comes on, but goes off when the central spoiler mounted one is working.
All seems very random. The bulbs are obviously working as all the lights work at some time or another. I'll try cleaning the connection plugs but I'm not sure what else to look at.
