Had to disconnect the battery the other day which reset the clock on the dash. I don't have an owners manual. Can someone tell me how to set the time on the dash clock? Cheers.
If you press and hold the button with the musical note on it, the clock will start to flash. Then, using the number 4 and 5 buttons, you can change the hour and minutes. Press the button with the musical note on it again to stop the clock flashing. Clock is now set.
