Shuddering noise
rhinogolf
York
7th&8th gen tourers
Hi back again over the last wk or so ive noticed very slight shudder noise when setting of in 1st then thats it car runs smooth also when sat in taxi rank with car ticking over noise in cabin as got louder. Im getting my alternator belt changed tomorrow to the new shorter belt. But the slight shudder when setting of in 1st as got me a bit worried been through the forum and DMF keeps jumping out at me but a few posts relate to inner cv joints which was an advisory from HH. Was getting a inde to do belt but now thinking should take to dealer so can check DMF as they fitted new 1 in august/september and get cv joints done.The car does not seem as healthy as normal was putting that down to not using castrol oil on last service dont get me wrong car runs great but you just no yourself s when car is purring it feels a bit sluggish.Also checked oil last night at work and oil mark was just over top mark on dipstick put this down to oil been warm have not checked today as 1 of my drivers is working the car and cant believe HH would overfill.Also since ive had the car it has always used over 1ltr of oil between services always used castrol. HH did my last service and used Honda oil and after 7k have not had to top up can any1 explain that. Got 140k on clock and stops drinking the oil can not work that 1 out
Well had belt changed,thats got rid of squeaking noise,garage said ive got a split bush behind the timing chain which could be causing the slight shudder when setting of in 1st. could not give me a price as the boss was not around and he did not no if it was a big job or not as he ran the spraying side of the business. Has for inner cv joints going he said this is very rare on hondas.Any1 got any input on this
Got all the above wrong been into garage this morning and what he said was he thinks rubber between crankshaft pulley has to much play in it hes not sure if this is right going to phone is pal at honda. Not much on this in forum. Any1 got any info on this
