freddofrog
won 16.4k on Euro lottery :)
My K24 engine squeaks quite often. When it squeaks, the noise is there at idle and when driving (I can only hear the noise with the window open).
I've opened the bonnet and it seems to be coming from the drive belt or tensioner. Both the tensioner and belt are original (it's a 54 plate and I've had the car for nearly 5 years). The belt is not cracked, the noise is not a slipping noise, but it seems to be worse in cold and/or damp weather.
I briefly spoke to the mechanic at the dealer, it was not making the noise at the time, he was very busy but he came out and felt the belt and said it was a dry belt.
Obviouslly I haven't squirted the belt with WD40 !!!!! nor have I put talcum powder on it (an old temp cure for a slipping belt).
Is there anthing one can spray on a "dry belt" ? If not, should I just get another belt and swap it to see if that stops it ? Is the tensioner an auto-adjust, should I try to slacken it and tighten it ?
