julekasMobilek
Hello guys, i just bought my accord, and after few week i started to search where are cracks and squeeks are coming from. So here is the video, do you have the same problems, how do you fix them?
https://www.youtube.com/watch?v=KDmqKa5PboY
1: it is possible to fix that silver rattling small thingy which is on top of cup holders? (0:10 sec in the video)
2: it is possible to fix that handbrake lever which is sliding. When it slides all the way out it is impossible to disengage the hand brake, you have to slide it back all the way (as it should be), then you can push the button and disengage it. (0:23 sec in the video)
3: it is possible to fix that loose handbrake, as you can see, it is very rattly loose first few clicks. Hand brake is engaged to the end holds my car very good. But it is very annoying that lever is very loose at the starting point. (0:35 sec in the video)
4: Can you guide me, how to take apart the center console (show the screes or holding brakets), to change gear stick leather gaiter (1:15 sec in the video), where to start and begin with? As you can see in the video all the trims is kinda loose, i would like to fix that
(0:17 sec in the video)
