Rustyrescue
- Messages
- 29
- Reaction score
- 2
- Car
- Accord
Hi, can anybody tell me where the tailgate control module/ecu is on a 2006 pre facelift 2.2 Diesel estate?
Hi , thanks to you both. Its actually a friends car...mine ok! the tailgate does not work at all, can only be opened with the emergency release. Neither the outside button or the remote work.It's under the roof liner at the rear where the tail gate loom enters but as Gray said there are a few other possible faults to dismiss before digging that out.
Hi Grayedout...thanks for asking, I think my posts now clarify....helping a mate from a distance! I think he should check the loom and the catch or solenoid (not sure what this car has) in the boot because if it does not work by plipper or the boot switch they could be at fault.Can I ask why you need to know? if you are having problems with the tailgate then it's usually due to broken wires between the tailgate and body.
HI, there is a tailgate warning light on dashboard......does that help us diagnose the issue?
