Water bearing maybe?
Ijimman
Worthing
2005 I-CTDI sport
K so I have my accord ictdi and it makes this annoying noise which sounds like a bearing to me that's got something in it perhaps. Its definately coming from a wheel powered by the belt. And I am loosing coolant /water at the rate of a full tank a day however that has dropped to like a quarter of a tank a day. Had the thermostat changed as well a week ago. Anybody else had this problem and know what it is?
And you really can't see where all that water is going?
Was it/is it overheating?
Does it otherwise run OK?
Noise 'from the belt' could be several things, but usually the alternator pulley... take the belt off and give all the pulleys a shake and spin them to see if you can work out which one it is. But the water leak must be your biggest problem.
