Window noises
skhell
Portugal
1.8, 6th gen Accord
Hi guys,
As the ***le says, the windows of my Accord make some noises when they are fully opened or fully closed, mainly on bad roads.
I have already removed the panel of one door to see if something was loose, but no, everything was all tight. Unfortunately forgot to take pictures...
I noticed that there is some gap between the plastic piece that holds the glass and the vertical slide. I guess that's from this gap that noise comes.
Now, my questions:
Is this normal in our cars?
When they were new, did they also made those noises?
Is there any solution(cheap) to solve this problem?
Are you talking about parts (5,10) or (3,8 and 4,9) of the following diagram?
http://www.hondaoriginalparts.com/honda_car_parts_selection_pfk.php?block_01=17S1A11&block_02=B__5300&block_03=2300
Either way, this tiny problem doesn't justify those prices, so they will just get like they are :rolleyes:
