acemace021
So the Xcarlink arrived today, so I spent an hour or so installing, i used the civi info guide My link.
Its a good guide the only thing I noticed was that it tells you to undo two screws at the bottom of ashtray near gear stick, you don't need to its only held in by the clips.
i fed my cables from glove box, one goes to back of stereo, and the other for the iPod. and the Bluetooth cable I have ran under the centre console trim to the driver door, on the dash I have temporarily stuck the Bluetooth module with tape, I have some special sided stuff, which I need to find to make it more permanent.
I have then ran the cable to the microphone up the pillar between windscreen and door, under the rubber seal, then I have clipped microphone to my sun visor.
I'm also going to conceal the xcarlink unit, behind my glove box once I find my tape. Here's a couple of photos.
I also have the up to date discount code if anyone would like it pm me.
