Franco
If the condensation is as bad as Stuarts, and Honda won't replace the headlights, then you'll need to take the lights out and reseal them. There must be a leak somewhere. I think someone posted about how they did this. http://typeaccord.co.uk/forum/topic/85-misted-headlamps-bulletin-recall/page__st__20
Franco, the clutch pedal can be easily solved: http://typeaccord.co.uk/forum/topic/86-clutch-pedal-creakclick/
Are the parking sensors a genuine honda fit or an aftermarket fit? Could be a blown fuse (reverse light), faulty sensor or buzzer.
Ok, had a good look at the sensors today. It's the genuine Honda item, but there seems to be a mile of unused cable bunched up under the plastic moulding at the back of the car. A bit of a messy job as nothing is even cable tied in place. When I looked closely at the control unit I noticed there was a small cut in one of the sensor cables. I'm fairly confident that I can fix this if the dealer decides not to. I'll just wait and see what happens on Saturday. Thanks for your comments by the way!
