Hard to tell how hooked the sprocket teeth are without having the item in my hand.
The general consensus is to change everything, as of course worn sprockets will quickly stretch a new chain.
The smaller ones will have done more work of course. If in doubt change them.
The oil pump chain is the one that likes to fail (due to doing more laps and being wound tighter) if you're on a budget i'd make them the priority.
Also check the tensioner guides for wear, and replace accordingly. If anything I'd expect the wear to be on the ones loaded by the tensioners, as they're working the hardest.
