H Peasource
Injector King
Keep going guys - I love a good argument, even if it has strayed a long way from the OP's problem!
Well yes, but right up until my final technical post I merely thought I was being helpful, not arguing...it came as something of a surprise!Keep going guys - I love a good argument, even if it has strayed a long way from the OP's problem!
I guess we've all been on forums where arguments can get very nastyWell yes, but right up until my final technical post I merely thought I was being helpful, not arguing...it came as something of a surprise!
Impedance and resistance are both measured in ohms, therefore I'm happy with your (very rough) estimate of what you are calling resistance (which is actually a combination of inductance and resistance). But please bear in mind that the starter cannot only be resistive, if it were then the only result of passing current through it would be a heating effect. A magnetic field is also set up in the windings which interacts in such a way as to cause rotation... this effort does not come for free, the inrush current is mostly due to initiating this magnetic field (which is why the cabling has to be so heavy duty), this inrush current is instantaneous and will only last a few milliseconds at most (then falls as the magnetic field is established and 'back EMF' kicks in). It will be higher with a stationary armature, but each time the spinning brush/commutator components re-make the circuit, then there will be a smaller instantaneous current (but smaller than when the armature was initially stationary). So yes, there is a high initial current drawn from the battery!i.e. I said that if the CCA of the battery is 330 Amps, then on a cold winter's day I ***ume that the starter will draw about 300 Amps initially, and ***uming initial voltage across the starter terminals is 12V, then using Ohms Law the resistance is 0.04 Ohms. I don't know if this is true, if it is, then it will be for the first few milliseconds I would think, after which the current would reduce due to back emf. Also, an unloaded starter motor (out of car) will not draw much current, so again Jon is onto something. However, the battery's rated CCA of 330 Amps does imply a very large initial current draw.
Not much (fractions of ohms)But reagrding the original post, it is kind of relevant, because it begs the question, how much resistance can you lose on the clamp before it starts to cause problems. If CCA of 330 Amps is needed, then you cannot lose much resistance on loose terminals.
No just needed clarify who's hand was on the willy when the writing in the snow was doneGlad that's sorted out then. I just had the feeling it might develop into a willy-waving contest.
