2001 accord type r starts and then dies
ThomasATR
Accord type R
Hi! Have a 2001 accord type r h22a7 engine
It’s fires initially and then dies, it has fuel and has spark, checked timing that is also correct, seems to lose injector pulse with noid light after it fires, checked wiring back to ecu and that side of it is fine, main relay checks out to be working, ignition switch seems to be working, if you crank it 3 times without pulling the key back it’ll eventually start up (weird) has no fault codes in it when it’s cranking but when it fires up it comes up with CMP Sensor A Intermittent interruption, to my knowledge that’s in the dizzy? It originally came up with a crank shaft sensor fault, which I replaced that and now it’s coming up with the CMP fault, It’s a new dizzy on the car, and when it starts it does run sweet, so unsure what to do next, any ideas where to look? Thanks guys
