Hi all.
As some of you may know, I've recently asked if there's any alternative to genuine PAS fluid...turns out there isn't. So I bought some and topped it up, not surprisingly I've now found the leak:
On the PAS rack there are two steel lines that connect at the 'knuckle', and one of them passes through a bracket which has subsequently chafed and made it rust. The only way forward is to drop the subframe and get proper access to all the pipework and replace what's needed.
This bring me onto my question: Are these dealer only parts or does anyone know anywhere else I can get them? The one that's gone is a steel pipe that joins to a rubber hose that connects to the top of the pump; all one piece and rather expensive.
Any help much appreciated.
