Here is a little tip when refitting the ff, I don't know if this has been mentioned so apologies if it has. When reffiting the ff to bulk head it can be tricky as we know but if you put a bit blue tac into the socket you can hold the ff in position with one hand and screw it in with the other using an extension bar and the blue tac stops you losing the bolt when getting into position to screw it on, simple but works very well.
