ROAD DETECTIVE
This may be something or nothing. I noticed it a couple of weeks ago. When accelerating in second gear between 1600-2500 revs there is a very slight vibration. It seemed to slightly rattle what I usually keep in the passenger door pocket. Most of the time you can just feel it, but strangely on the odd occasion you can't. It only happens in this gear and rev range. In all other gears and revs it is super smooth. On tickover also smooth. If you hold the revs in this range steady, no vibration. I think most drivers would not really know there is a problem, but it was not there before. I already have had a new clutch, DMF and offside driveshaft about 13k ago. I looked and found a fair bit of play in the N/S driveshaft, confirmed by my usual mechanic and so I have just had a new one fitted, along with getting the front wheels tracked. Still got that darn slight vibration exactly the same as before. I have done about 800mls since it first started and it has not got any worse. The car is on 90k. This car since I bought it early last year has cost me a small fortune! Knew I should have kept the super reliable CTR. Any experts got an opinion on the problem, or should I just ignore it until it either gets worse, or I get lucky and it stays the same. Anybody else got a long term slight vibration they have ignored and has caused no problems. I have read other posts where members have got something similar which they can't fully get rid of.
