ABS problem
Jimslim13
Accord gen8
Hi all. Need advice on my abs system. Have found that when abs/esp activates, everything seems to work ok. I can feel the pedal pulsing and car slows down as expected. However, when you push the brake pedal again it goes to the floor with no pressure. Pressure will build back up again after 2-3 pumps of the pedal. Guessing it has something to do with bypass valves on abs module during activation. Any ideas to test it to be sure of any fix
Should have said it's a 2010 EX-GT
